Mz700 repair project
CRG
Re: Mz700 repair project
Post by CRG »
I might be better leaving well enough alone then. Its done nothing but rain here and the forecast is not good for the coming days so I've time to mull it over but last thing I need is to loose the lettering.
The machine works again so for now maybe I should concentrate on some software.
Gortho
Post by Gortho »
Maybe somebody will be interested in a spare parts donor. there is one quite cheap on ebay. (at least still.)
https://www.ebay.pl/itm/Sharp-mz700-64k ... SwvaBcwDdw
Postage might be quite steep, but maybe it's worth looking at.
shipping is over €30...
marcushg
Post by marcushg »
hlide wrote: Tue Mar 19, 2019 7:38 pm I tried to retrobright some MZ-700 keys without UV using only H2O2 and heat through a sous-vide cooker (not sure how to call that machine).
But I got a better result with TO8 keys as I could refine the experiment.
Before:
After:
Sorry I'm resurrecting this old post. I just got an mz 800 that is missing the Del key, i think it's the same as Fs is it possible to get the stls? That would be lovely. Thanks
Here's the STL of the F-key I printed for my 700.
MZ700 F-key.zip
(29.5 KiB) Downloaded 2365 times
jaume-anton
Post by jaume-anton »
Hello.
I'm new in this forum. I have a MZ700 and I have lost 2 keys and break 3 stems in a "little" accident at home. The keys are "J" and "M".
Could someone help me to restore my keyboard, please? Thank you very much.
marcushg
Post by marcushg »
Jo Even wrote: Mon Sep 19, 2022 11:52 am Here's the STL of the F-key I printed for my 700.
Thanks a lot!!! will print it now :)
jaume-anton wrote: Tue Sep 20, 2022 1:02 pm Hello.
If you have (access to) a 3D printer you could print new keycaps. I can upload the STL for these if you're interested.
The stem is another issue though. I have tried to 3D-print a new stem, but they are just too finely detailed for my printer. I repaired the stem with a bit of Lego: viewtopic.php?f=3&t=347&p=956#p956
With a 3D resin printer, it could be finer?
jaume-anton
Jo Even wrote: Thu Sep 22, 2022 5:55 pm
I have a 3d printer. Please, if you upload the stl files I think that I could solve my problem.
Thank you very much! :)
